Set up a connection to PlentyONE
PlentyONE helps businesses run their entire e-commerce operation from one platform.
Setting
Instructions
Name your connection *
Host prefix *
Enter your PlentyONE account host prefix. If your URL is https://p12345.my.plentysystems.com/, then p12345 is your host prefix.
Username *
Enter your PlentyONE username.
dataLoad.svg​​ How to retrieve the username
Password *
Enter your PlentyONE password.
Multiple layers of protection, including AES 256 encryption, are in place to keep your password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
dataLoad.svg​​ How to retrieve the password
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see token universal connector documentation.
How to retrieve the username and password
  1. Sign in to your PlentyONE account.
  2. Navigate to Setup > Account management > Accounts.
  3. Click New account.
  4. Enter the Username.
  5. Enter the Password.
  6. Select the Rights.
  7. Click Save.
Additional references
