Set up a connection to Base.com
Base.com is an all-in-one e-commerce platform that enables businesses to create, manage, and scale online stores, marketplaces, and integrations from a single unified system.
Setting
Instructions
Name your connection *
API token *
Enter your Base.com API token.
Multiple layers of protection, including AES 256 encryption, are in place to keep your API token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
dataLoad.svg​​ How to retrieve the API token
  1. Sign in to your Base.com account.
  2. Navigate to My account > API.
  3. Click + Add API token.
  4. Enter a Name.
  5. Select the Scope API permission.
  6. Click Save.
  7. Copy the generated API token.
