Set up a connection to Happy Returns
Happy Returns provides comprehensive return solutions for leading online and omni-channel retailers and their customers.
After you start the connection , you have to configure it in the Create connection panel and must complete all of the required * authentication settings:
Setting
Instructions
Name your connection *
API key *
Enter your Happy Returns API key.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see token auth universal connector documentation.
How to retrieve the API key
  1. Sign in to your Happy Returns account.
  2. Navigate to Settings > Developer tools .
  3. Click Generate new key.
  4. Select the required APIs/webhooks access.
  5. Click Generate new key. The Save your API key screen appears.
  6. Copy the API key and secure it in a safe place. For more information on how to generate a new key, see  Generate an API key.
Make sure to copy your new API key as you cannot see the API key again.
