Set up a connection to Fulfil
Fulfil is a cloud ERP platform built for e-commerce and wholesale businesses to manage inventory, orders, financials, and operations in one unified system.
Setting
Instructions
Name your connection *
API type *
Choose your Fulfil API type:
  • Channel: Sync orders, products, inventory, and fulfillment updates with sales channels.
  • 3PL: Send fulfillment requests and sync shipment details with third-party logistics providers.
  • Carrier: Create labels, get rates, and sync tracking updates with shipping carriers.
Merchant subdomain *
Enter your Fulfil channel merchant’s subdomain. For example, if your URL is https://apple.fulfil.io, then apple is your subdomain.
Channel JWT *
Enter your Fulfil channel merchant’s JWT. For detailed information, see Tokens.
Enter your Fulfil 3PL merchant’s subdomain. For example, if your URL is https://apple.fulfil.io, then apple is your subdomain.
3PL JWT *
Enter your Fulfil 3PL JWT. For detailed information, see Tokens.
Callback base URL *
Enter your Fulfil carrier merchant’s callback base URL.
Username *
Enter your Fulfil carrier merchant’s account username.
Password *
Enter your Fulfil carrier merchant’s account password.
Multiple layers of protection, including AES 256 encryption, are in place to keep your password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Additional references
