LBMX is a B2B buying group and purchasing cooperative platform that helps independent businesses, suppliers, and buying groups streamline procurement, rebate management, EDI, analytics, invoicing, and eCommerce through a centralized marketplace.
The LBMX connector is in BETA and may be subject to changes.
API key * |
Enter your LBMX API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Document type * |
Enter your LBMX account document type. For example, if your URL is |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see Token universal connector documentation.
