JTL is an e-commerce management system designed to help businesses run online sales across multiple platforms from one place.
The JTL connector is in BETA and may be subject to changes.
API type * |
Choose your JTL account API type:
JTL SCX API type |
Environment * |
Select your JTL account environment:
Token * |
Enter your JTL account token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
JTL WAWI API type |
Tenant ID * |
Enter your JTL account tenant ID. For example, if your JTL account URL is |
Application ID * |
Enter your JTL account application ID. |
Application version * |
Enter your JTL account application version. |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by JTL. For detailed information, see Authentication. To add an OAuth 2.0 client and configure your credentials, click the plus (+ ) button. Click the edit ( |
Scopes * |
Scopes are OAuth 2.0 permissions that JTL defines to limit access to your account. |
