- Analytics-ready data
Data that has been loaded and structured so that it can be efficiently queried, reported on, or modeled for analysis.
- Analytics store
A destination system, such as a data warehouse or data lake, where ingested data is stored for access, reporting, and analysis.
- Append
A load behavior that adds incoming records to the destination without replacing existing records.
- Backfill
An initial or historical load of existing source data into the destination.
- Celigo sync
A Celigo data ingestion pipeline that moves operational data from source applications into analytical destinations, such as Snowflake or NetSuite Analytics Warehouse.
- Connection
A Celigo resource that stores the authentication and access details required to connect to a source or destination application.
- Data ingestion
The process of exporting data from source systems, such as applications, data stores, or files, and loading it into an analytics destination, such as a data warehouse or data lake.
- Data integration
The process of programmatically moving, combining, restructuring, or harmonizing data from one or more systems for use in other systems, reporting, analysis, or operations.
- Data lake
A centralized analytics destination that stores large volumes of raw or lightly processed data for later analysis, transformation, or modeling.
- Data loader
A Celigo tool that loads a single locally stored file into an application on demand while the user is logged in.
- Data masking
A transformation that hides, replaces, or obscures sensitive values before or during loading.
- Data type
A classification that defines the kind of value a field or column can store, such as text, number, date, or Boolean.
- Data type mapping
The process of matching source field data types to compatible destination column data types.
- Data warehouse
A centralized analytics destination designed to store structured data for reporting, querying, and analysis.
- Destination application
The data warehouse or analytics destination into which a sync loads source data.
- Destination schema
The schema created in the target database to contain the tables generated and maintained by a sync.
- Event log
A record of sync events, such as detected schema drift or operational activity.
- Export source selection (standard ingestion)
A lightweight, protocol-agnostic ingestion method utilizing universal HTTP transport mechanisms to systematically stream raw data structures from over 600+ SaaS applications directly into a data store landing zone. (See Extract sync source data from objects vs. exports.)
- Extract
To retrieve data from a source system for use in a sync, flow, or other integration process.
- Extract load transform (ELT)
A data integration pattern in which data is extracted from a source, loaded into a destination in native or near-native form, and transformed after loading.
- Extract transform load (ETL)
A data integration pattern in which data is extracted from a source, transformed before loading, and then loaded into a target system.
- Flattening
A modeling approach that converts nested or hierarchical data into a simpler table structure.
- Governance
The policies, controls, and practices used to manage data access, structure, change handling, and operational oversight.
- Hierarchical data
Data organized in nested parent-child structures, such as records that contain related subrecords or arrays.
- Historical sync
A sync run that loads source data beginning from a selected historical date.
- Integration workspace
A Celigo organizational container that groups related syncs or integrations. For Celigo sync, a workspace contains syncs that use the same destination application.
- Lakehouse
An analytics architecture that combines characteristics of a data lake and a data warehouse to support flexible storage and analytical workloads.
- Load
To write extracted data into a destination system, such as a data warehouse table.
- Merge
A load behavior that updates matching destination records and inserts new records.
- Metadata
Information that describes data, such as object names, field names, data types, relationships, and other structural characteristics.
- Normalization
A modeling approach that organizes related data into separate, structured tables to support analysis.
- Object source selection (rich application-aware experience)
The premier Celigo ingestion method where the platform natively reads source system metadata (from applications such as NetSuite, Salesforce, and Shopify) to automatically discover objects, accurately map data types, manage structural changes, and build analytics-ready target tables out-of-the-box without requiring manual database configuration.
- Polling
A scheduled check for new or changed source data to ingest during an incremental sync.
- Primary key (PK)
A field or set of fields used to uniquely identify records in a table or object.
- Replace
A load behavior that overwrites existing destination data with incoming source data.
- Role-based access control (RBAC)
An access control model that grants permissions based on assigned user roles.
- Runtime
The Celigo platform execution environment that runs flows and syncs.
- Schema
A logical structure in a destination database that contains the tables created for a sync.
- Schema drift
A change in source or destination structure, such as added or removed objects, added or removed columns, or changed data types.
- Source application
The application, database, file source, or other system from which a sync exports data.
- Source metadata
Metadata supplied by a source application that describes available objects, fields, data types, and related structure.
- Sync
A configured Celigo sync resource that defines a source application, destination application, selected data, destination schema, settings, and schedule for ingesting data.
- Transform
To change the structure, format, value, or representation of data so that it meets destination or analytics requirements.
- Upsert
An operational database write behavior that combines “Update” and “Insert.” It scans incoming records against designated primary keys; if a matching key is identified in the target table, the row is updated with new metrics, and if no match exists, a new row is cleanly inserted. Often used interchangeably with “Merge.”
Data ingestion terminology and acronyms
Stephen Brandt
