Use ILM with tools
Tools participate in ILM the same way flows and integrations do. Use ILM to move tool changes safely between environments, such as sandbox, staging, and production. Tool definitions, dependencies, and references are promoted automatically, helping you maintain consistency across environments.
When you create a snapshot, pull, or revert, integrator.io automatically includes everything the tool depends on, you don't need to add these separately:
  • Referenced tools and nested tools
  • Lookups, imports, scripts, and lookup caches
  • Connection mappings for the tool and all tools it references
Promote tool changes:
When a tool is modified in a lower environment and included in a pull:
  • Tool changes appear in the pull comparison
  • Referenced tool dependencies are included automatically
  • Existing tool references are preserved
For example, if an AI agent or a flow references to a tool, you do not need to reconnect the tool after promotion.
Flows and agents that reference tools can be included in a snapshot or pull. When promoted:
  • Referenced tools and their nested dependencies are included automatically
  • Tool references remain intact, no rebinding needed after promotion
  • If a tool referenced within a flow belongs to a different integration, ILM creates it in the target integration automatically
Validation before promotion
Before completing a promotion, ILM validates that required tool configuration exists in the target environment.
This includes:
  • Connections
  • Tool dependencies
If required configuration is missing, ILM displays an error and prevents the promotion until the issue is resolved.
Ignore fields during a pull
You can ignore the following tool-related fields during a pull:
Resource
Fields you can ignore
Tool
Name, description
Tool sub-steps
All supported export and import fields
Tool import step
All supported import step fields
Tool input and Tool output fields cannot be ignored during pull operations.
Pull and revert behavior
Scenario
What happens
Pull or revert within the same environment
Always creates a new tool resource
Pull or revert across environments
Updates the existing tool if it was previously promoted; creates it fresh if not
Cloning (any environment)
