CaptivateIQ is a cloud-based sales performance management (SPM) and incentive compensation management platform that helps organizations automate commission calculations, compensation planning, and sales performance tracking.
The CaptiveIQ connector is in BETA and may be subject to changes.
API token * |
Enter your CaptivateIQ account API token. For more information on retrieving the API token, see Generating an auth token. Multiple layers of protection, including AES 256 encryption, are in place to keep your API token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Token auth universal connector's respective documentation.
