Real-time export flows that use SuiteScript 1.0 work in SuiteApp. Previously, real-time exports in SuiteApp required SuiteScript 2.0. No configuration changes are required — existing real-time flows using SuiteScript 1.0 will work automatically after the update.
The findSublistLineWithValue() API began requiring native boolean values (true/false) for checkbox fields instead of the previously accepted string values ('T'/'F'). This caused SuiteApp to fail to locate existing default billing and shipping address lines, resulting in duplicate address subrecords being created on update. Address book updates work as expected. This fix is backward-compatible with NetSuite 2025.2 and 2026.1.
