Set up a connection to Rillet
Rillet is an AI-powered accounting platform that helps companies automate accounting workflows and financial reporting.
After you start the connection, configure it in the Create connection panel and complete all of the required * authentication settings:
Setting Instructions
Name your connection *
Environment *
Select your Rillet account environment:
  • Production: if your account URL is https://api.rillet.com
  • Test: if your account URL is https://sandbox.api.rillet.com
API key * Enter your Rillet API key. For detailed information on retrieving the API key, see Authentication.
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Token auth universal connector documentation.
Additional references
