Set up a connection to 3 Clicks Cloud
3 Clicks Cloudis a cloud-based Product Lifecycle Management (PLM) platform that helps fashion businesses manage product development, production, and supplier collaboration.
After you start the connection, configure it in the Create connection panel and complete all of the required * authentication settings:
Setting Instructions
Name your connection *
API type *
Choose your 3 Clicks Cloud API type:
  • Simple: Authenticate using your API key and secret for quick API access.
  • Strict: Authenticate using an API key, HMAC signature, and timestamp for enhanced security.
API version * Select your 3 Clicks Cloud API version (v1 or v2).
Domain * Enter your 3 Clicks Cloud domain. For example, if your URL is https://celigo-server.instance.3clickscloud.com/api-user/v1 then celigo-server.instance.3clickscloud.com is the domain.
API key * Enter your 3 Clicks Cloud API key provided by your administrator.
API secret * Enter your 3 Clicks Cloud API secret provided by your administrator.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API secret safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text.
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Token auth universal connector documentation.
Additional references
