Set up a connection to Hyperbolic
Hyperbolic is an AI cloud platform that helps developers and businesses access affordable GPU compute, serverless inference, and AI infrastructure to build, train, and deploy AI applications at scale.
After you start the connection, configure it in the Create connection panel and complete all of the required * authentication settings:
Setting Instructions
Name your connection *
API key * Enter your Hyperbolic API key. For detailed information on retrieving the API key, see Authentication.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text.
Additional references
