Set up a connection to Mistral
Mistral is an enterprise AI platform that enables organizations to build AI assistants, automate workflows, and process documents using large language models.
After you start the connection, configure it in the Create connection panel and complete all of the required * authentication settings:
Setting Instructions
Name your connection *
API key * Enter your Mistral API key. For detailed information on retrieving the API key, see Generate an API key.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text.
Additional references
