Anrok is a sales tax automation platform that helps businesses calculate, manage, and comply with sales tax requirements.
| Setting | Instructions |
| Name your connection * |
| API key * | Enter your Anrok API key. For detailed information on retrieving the API key, see Create an API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your access token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
