Fireworks AI is an AI inference platform that enables developers and enterprises to build, deploy, and scale generative AI applications using high-performance APIs for large language models (LLMs), image models, speech models, and embedding models.
| Setting | Instructions |
| Name your connection * |
| API key * | Enter your Fireworks AI API key. For detailed information on retrieving the API key, see Getting your API key. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the token universal connector documentation.
Additional references
