Cohere is an AI platform that provides large language models and APIs for building generative AI applications.
| Setting | Instructions |
| Name your connection * |
| API version | Select your Cohere account API version. |
| API key * | Enter the Cohere API key. For detailed information on retrieving the API key, see Creating an API key. Multiple layers of protection are in place, including AES-256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
