DealHub is a quote-to-revenue (Q2R) platform that streamlines CPQ, contract management, and deal approvals.
| Setting | Instructions |
| Name your connection * |
| API type * |
Choose your DealHub API type:
| Token * | Enter the DealHub token. For detailed information on retrieving the token, see Authentication. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s token safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
| Specific to External API type: | |
| External API base URL * | Enter your external system API base URL that hosts DealHub External query or Callout endpoints. For example, https://api.acmecorp.com/dealhub/data-query
| Auth type * | Select your DealHub External API authentication type (Basic or Token) |
| Username * | Enter the External system username. |
| Password * | Enter the External system password. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
