Set up a connection to Crusoe
Crusoe is a cloud platform that provides AI infrastructure and cloud computing services for building, deploying, and scaling machine learning and generative AI workloads.
Setting Instructions
Name your connection *
API type *
Choose your Crusoe API type:
  • Cloud: Provision, manage, and monitor cloud infrastructure resources, including virtual machines, storage, networking, projects, organizations, quotas, usage, audit logs, and other infrastructure services.
  • Managed AI: Manage AI resources, including models, deployments, credentials, inference, fine-tuning, and other AI services for building and running generative AI applications.
Specific to Cloud API type
API version Select your Crusoe account API version.
Access key * Enter your Crusoe access key. For detailed information on retrieving the access key, see Create API key.
Secret key *
Enter your Crusoe secret key. For detailed information on retrieving the access key, see Create API key.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s secret key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text.
Specific to Managed AI API type
API key * Enter the Crusoe token. For detailed information on retrieving the access key, see Create API key.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s token safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text.
Additional references
