Set up a connection to PerformYard
PerformYard is a performance management software designed for HR teams to run reviews, set goals, and manage employee feedback.
After you start the connection, configure it in the Create connection panel and complete all of the required *authentication settings:
Setting Instructions
Name your connection *
API version Select your PerformYard API version (v1 or v2).
API ID * Enter your PerformYard API ID. For detailed information on retrieving the API ID, see Creating your API key.
API key *
Enter your PerformYard API key. For detailed information on retrieving the API key, see Creating your API key.
Additional references
