Set up a connection to DataRobot
DataRobot is an enterprise AI platform designed for organizations to build, deploy, and manage machine learning and generative AI applications.
After you start the connection, configure it in the Create connection panel and complete all of the required *authentication settings:
Setting Instructions
Name your connection *
Region *
Select your DataRobot account region:
  • US: if your account URL is https://app.datarobot.com
  • EU: if your account URL is https://app.eu.datarobot.com
  • JP: if your account URL is https://app.jp.datarobot.com
API key *
Enter your DataRobot API key. For detailed information on retrieving the API key, see Keys.
Multiple layers of protection, including AES-256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when you save the connection and is never displayed as text.
Additional reference
