Airwallex is a global financial platform designed for businesses to manage cross-border payments, foreign exchange, and international banking operations.
| Setting | Instructions |
| Name your connection * |
| Environment * | Select your Airwallex account environment (Production or Sandbox). |
| Client ID * | Enter your Airwallex client ID. For detailed information on retrieving the client ID, see Keys. |
API key * |
Enter your Airwallex API key. For detailed information on retrieving the API key, see Keys. Multiple layers of protection, including AES 256 encryption, are in place to keep your access token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Additional reference
