EBizCharge is a payment processing software designed for businesses to integrate credit card and ACH payments into their accounting, ERP, and CRM systems.
| Setting | Instructions |
| Name your connection * |
| Security ID * | Enter your EBizCharge security ID. |
| User ID * | Enter your EBizCharge user ID. |
| Password * | Enter your EBizCharge password. |
EBiz subscription key * |
Enter your EBizCharge subscription key. Multiple layers of protection, including AES-256 encryption, are in place to keep your key safe. When editing this connection, you must re-enter this value each time; it is stored only when you save the connection and is never displayed as text. |
