Use this article when a submit request is rejected, a job fails or never finishes, a result looks wrong, or a status or results request returns an error. A rejection at submit returns a 4xx with an errors array, and no job exists. A failure after submit shows up as status: "failed" on the job with an error code and message. Each section below is named for what you see and lists the causes to check, in order. For the full code catalog, see Celigo Storage query API reference.
The submit request is rejected
A rejection happens before the query runs: the response is a 4xx, errors[0].code names the check that failed, and no job exists. Check the following causes in order.
The statement isn't a single
SELECT.STORAGE_QUERY_NOT_SELECTmeans the statement is outside theSELECTfamily, which includesWITH,DESCRIBE, andSUMMARIZE, or is aSHOWform that lists engine state.STORAGE_QUERY_MULTIPLE_STATEMENTSmeans the request carries more than one statement. Remove the second statement. A single trailing semicolon is fine. -
The SQL didn't parse, is empty, or is too long.
STORAGE_QUERY_INVALID_SQLcarries the parser's message.STORAGE_QUERY_SQL_REQUIREDmeans thesqlfield is missing or blank.STORAGE_QUERY_SQL_TOO_LARGEmeans the statement exceeds 16 KB. Shorten it or split it. -
A function isn't allowed.
STORAGE_QUERY_FUNCTION_NOT_ALLOWEDnames the function. Functions that report engine or host state, such asversion(),current_setting(), andgetenv(), are never allowed. A misspelled function name produces the same error. -
A table function isn't allowed.
STORAGE_QUERY_TABLE_FUNCTION_NOT_ALLOWEDmeans the statement calls a table function other than the file readers (read_csv,read_json,read_ndjson,read_parquet, and their_autovariants),unnest,generate_series, orrange. Reference a storage path instead. Functions such asglob,read_text, andqueryare never allowed. -
A row generator isn't bounded.
STORAGE_QUERY_GENERATOR_ARGUMENT_NOT_LITERALmeans an argument ofgenerate_seriesorrangeisn't a whole-number literal — Celigo has to know the row count before the query runs.STORAGE_QUERY_GENERATOR_TOO_LARGEmeans the row counts of the statement'sgenerate_seriesandrangecalls, multiplied together, exceed 1,000,000. This applies even when the calls are in separateUNION ALLbranches. Lower a bound. -
The query reads no storage file.
STORAGE_QUERY_NO_STORAGE_REFERENCEmeans the statement generates rows, through a generator, a recursive common table expression, orunnestof a literal list, without reading any file. Add a file reference. A statement of constant expressions alone, such asSELECT 1, is allowed. -
A reader call is malformed.
STORAGE_QUERY_READER_PATH_NOT_LITERALmeans the first argument of a reader isn't a literal path string or a literal list of them.STORAGE_QUERY_INVALID_READ_OPTIONnames an option the reader doesn't accept, a duplicate, a positional argument, or a value of the wrong type —filename,hive_partitioning, andencodingare never accepted.STORAGE_QUERY_READER_FORMAT_MISMATCHmeans the reader doesn't match the file's format, for exampleread_jsonon a.csvfile. -
A path isn't a valid storage path.
STORAGE_QUERY_INVALID_SOURCEnames theFROMtarget. The usual causes are a wildcard (*or?aren't valid path characters), a schema-qualified name such asinformation_schema.tables, a.or..segment, or a character that Celigo Storage doesn't allow in names. Reference a folder with a trailing slash instead of a pattern. -
The query is too big.
STORAGE_QUERY_TOO_MANY_SOURCESmeans the statement references more than 10 distinct paths.STORAGE_QUERY_INPUT_TOO_LARGEmeans the files it would read total more than 10 GB. Reference fewer paths, or a smaller folder.
A file or folder is not found
404 STORAGE_QUERY_SOURCE_NOT_FOUND names the path. Check the following causes in order.
- The path is wrong. Compare it with the path on the File storage page, including case. The leading slash is optional; everything else must match.
- The path is outside your token's scope. A path your Custom token can't reach returns the same not-found error as a path that doesn't exist. Check the token's File storage paths. See Access is denied.
- The file was deleted. A file in the recycle bin is not found. Restore it or reference another file.
- A parent folder in the path doesn't exist. The error names the whole reference, not the missing segment. Check each folder in the path.
Three related errors are about the shape of the reference rather than its existence.
422 STORAGE_NOT_A_FILE— The path names a folder but has no trailing slash, so Celigo looked for a file. Add the trailing slash:'/staging/orders/'. -
422 STORAGE_ITEM_NOT_FOLDER— The path names a file but ends in a slash, so Celigo looked for a folder. Remove the trailing slash:'/staging/orders.csv'. -
422 STORAGE_ITEM_NOT_ACTIVE— The file's upload hasn't completed. Wait for the upload to finish, then submit again.
422 STORAGE_AMBIGUOUS_PATH means two folders with the same name exist at the same level of the path. Celigo Storage no longer allows this when a folder is created, so it affects only folders created before that check. Rename one of them.
Access is denied
Celigo reports a file your token can't read as not found, never as forbidden. Check the following causes in order.
- The token's File storage paths don't cover the reference. A Custom token reads only files at or under the folders in its File storage paths. The reference itself must be inside a granted folder — Celigo denies a reference to a parent of a granted folder even though some of its contents are in scope. Edit the token's paths, or reference the granted folder directly.
The token is a Custom token with no File storage paths. Such a token can't reach Celigo Storage at all, and the submit request fails with
401 STORAGE_QUERY_ACCESS_REFUSEDand the messageYou don't have the required permissions to perform the action.Add the folders to the token's File storage paths, or use a Full access token. -
The request carries an account-sharing header with a path-scoped token.
403 STORAGE_SCOPED_TOKEN_ASHARE_NOT_ALLOWEDmeans the request sent anintegrator-ashareidheader with a Custom token that has File storage paths. Remove the header. - A personal access token's role doesn't cover the file. A personal access token reads what its user can open. A file in an integration the user's role doesn't cover is reported as not found. Ask an account administrator for access to the integration, or use an API token.
The feature isn't enabled
403 STORAGE_QUERY_NOT_ENTITLED with the message Storage query is not enabled for this account means querying isn't enabled for the account that owns the token. Querying Celigo Storage is enabled per account for Professional and Enterprise customers. Every submit, status, and results request returns it, including requests for jobs submitted while the feature was enabled.
A folder mixes file formats
422 STORAGE_QUERY_MIXED_FORMAT_FOLDER names the folder, not the files. Every file directly inside a queried folder must share the same extension and MIME type, so Celigo rejects .csv beside .json, and .json beside .ndjson. It also rejects .csv beside .tsv, and two files with the same extension but different MIME types, for example a.csv recorded as text/csv beside b.csv recorded as application/octet-stream. Files uploaded through different tools can carry different MIME types for the same extension; the Celigo CLI records .ndjson, .jsonl, and .parquet files as application/octet-stream. Move each format into its own folder and combine them with UNION ALL, or reference the files individually. Related rejections:
422 STORAGE_QUERY_UNSUPPORTED_FILE_TYPE— A file in the reference has an extension and MIME type that Celigo can't map to CSV, JSON, NDJSON, or Parquet. Rename the file with a supported extension, or move it out of the folder. -
422 STORAGE_QUERY_FOLDER_EMPTY— The folder holds no files with completed uploads. Files in subfolders don't count. -
422 STORAGE_QUERY_FOLDER_TOO_MANY_FILES— The folder holds more than 100 files. Split the files across folders and combine the folders in the statement.
A file is empty
Celigo doesn't reject a zero-byte file. A query over it completes with zero rows, and its columns show a single placeholder column, because that is what the engine infers from an empty file. A zero-byte file inside a folder contributes no rows to the folder's result. If you expected rows, check that the flow or transfer that writes the file has completed.
The job failed with a timeout
STORAGE_QUERY_TIMEOUT on the job means the query ran for more than 300 seconds. The timeout counts from startedAt, not from submission. Check the following causes in order.
The query reads more data than it needs. Add a
WHEREclause, reference a smaller folder, or select fewer columns. Total input is capped at 10 GB, and a query near the cap that also sorts or joins can take minutes. -
The query sorts or joins the whole dataset. A global
ORDER BYover gigabytes, or a join whose smaller side is itself large, has to materialize the data. Filter first, or aggregate before you sort. - The files are slow to parse. JSON with deep nesting parses more slowly than CSV or Parquet. If you query the dataset often, store it as Parquet.
The job failed during execution
STORAGE_QUERY_EXECUTION_FAILED carries the engine's message, which names the storage path. Check the following causes in order.
A column's type drifted past the inference sample. The message reads like
Could not convert string "text" to 'BIGINT'. The engine inferred the type from a sample of rows, and a later row, or a later file in the folder, didn't fit. Widen the sample withsample_size, declare the column's type withtypesfor CSV orcolumnsfor JSON, or setignore_errors = truefor CSV and NDJSON. See Celigo storage query read options and format behavior. -
A cast failed. Replace
CASTwithTRY_CAST, which returnsNULLinstead of failing. - A file was purged after submit. The file list is fixed at submit, so a file permanently deleted (purged from the recycle bin) before the job ran fails the read with an HTTP 404 message. Submit the query again. A file moved to the recycle bin is still read, and a replaced file is read with its new contents.
A JSON file isn't in the format the reader expected.
ignore_errorsis accepted onread_jsonbut only takes effect for newline-delimited JSON. On a JSON array file, the engine reports that parse errors can't be ignored. Fix the file, or convert it to NDJSON. -
A column in the header is reported as not found, or every line lands in one column. One malformed CSV row, such as a row with an extra field, can change what format detection decides for the whole file. The file may come back as a single column named
a,b, or fail withBinder Error: Referenced column "b" not found. Read the file withread_csvandignore_errors = true, or setdelim,names, andtypesexplicitly.
STORAGE_QUERY_WORKER_FAILED means the process running the query stopped unexpectedly. Submit the query again. If it recurs on the same statement, reduce the amount of data it reads and contact Celigo Support with the jobId.
STORAGE_QUERY_JOB_INTERRUPTED means Celigo's service stopped while it held the job, for example during a deployment. The statement itself isn't at fault. Submit it again.
The job stays running
A job normally reaches completed or failed within 300 seconds of startedAt, plus a few seconds. If a job is still running well past that, the service that held it stopped without recording a result. Celigo marks the job failed with STORAGE_QUERY_JOB_INTERRUPTED, normally within about 7 minutes. Submit the query again as a new job. If a job stays running for much longer than that, or this happens repeatedly, contact Celigo Support with the jobId.
Values look wrong in the result
Whole numbers are strings.
"qty": "10"is expected. The engine infers whole-number columns as 64-bit integers, and 64-bit integers, unsigned 64-bit integers, 128-bit integers, and decimals arrive as strings.COUNT,SUMover integers, and//follow the same rule.AVGand/return numbers. To get a number, declare the column asINTEGERin the reader'stypesoption, or cast the expression. -
A division result is
null. Dividing by zero produces infinity or not-a-number, which have no JSON representation, so Celigo emitsnull. To handle a zero denominator in the statement instead, guard it withCASE WHEN qty = 0 THEN NULL ELSE total / qty END. -
A nested value is a string of JSON. A key whose values have different types across records is typed as
JSONand arrives as JSON text, and its column is reported asVARCHAR. Nesting below amaximum_depthyou set on the JSON reader behaves the same way; withoutmaximum_depth, nesting is typed at any depth. Extract the fields you need withjson_extractand cast them. -
Rows of
NULLs from an NDJSON file. Withignore_errors = true, a malformed NDJSON line comes back as a row ofNULLs rather than being skipped. Filter it out, for exampleWHERE id IS NOT NULL. -
Columns from one file are missing or
NULLfor another. Celigo combines the files in a folder by column name by default. A file that lacks a column producesNULLfor it, and a renamed column appears as two half-filled columns. Declarenamesandtypeson the reader, setunion_by_name = falseto keep only the first file's columns, or fix the files. -
Two runs of the same query disagree.
random(),now(), and other nondeterministic functions produce a new value on each run.
A status or results request fails
404 STORAGE_QUERY_JOB_NOT_FOUND. ThejobIdis wrong, the job was submitted by a different identity, or the job finished more than about 24 hours ago and its record has expired. Submit the query again if you still need the result. -
400 STORAGE_QUERY_INVALID_JOB_ID. ThejobIdisn't a valid identifier. Copy it exactly from the submit response. -
409 STORAGE_QUERY_JOB_NOT_READY. The job isn'tcompleted. Poll the status endpoint until it is. Afailedjob has no results. -
400 STORAGE_QUERY_PAGE_OUT_OF_RANGE.pageis abovepageCountor isn't a positive integer. Page numbers start at 1. A job with no rows haspageCount: 0, and onlypage=1is valid for it.
The service is throttled or unavailable
429 STORAGE_QUERY_RESOLVER_RATE_LIMITED— Too many requests reached Celigo Storage while it looked up your paths. Wait and submit again with a longer interval between requests. Celigo never rejects a submission because your account already has several jobs running — that job waits in the queue. -
503 STORAGE_QUERY_RESOLVER_UNAVAILABLE— Celigo Storage couldn't look up your paths. Retry shortly. -
503 STORAGE_QUERY_ENQUEUE_FAILED— The query passed every check but couldn't be queued. No job exists. Retry shortly. -
500 STORAGE_QUERY_REWRITE_VERIFICATION_FAILEDorSTORAGE_QUERY_RESOLVER_REJECTED_REQUEST— An internal check failed. Retry once. If it recurs, contact Celigo Support with the statement and the time of the request.
