Set up a connection to GMI Cloud
GMI Cloud is a cloud platform that provides on-demand GPU compute and inference infrastructure for deploying and scaling AI models.
Setting Instructions
Name your connection *
API type *
Choose your GMI Cloud API type:
  • Compute Service: Connect to your GMI Cloud infrastructure to provision and manage GPU compute resources like bare-metal servers, containers, VPCs, firewalls, elastic IPs, and images across GMI Cloud data centers
  • Sandbox data plane: Connect to a running sandbox to execute commands and manage files to run shell commands, check or cancel executions, and upload or download files
Compute service API
API version  Select your GMI Cloud API version.
API key *
Enter your GMI Cloud API key. For detailed information on retrieving the API key, see Authentication.
Multiple layers of protection, including AES-256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Sandbox data plane API
Sandbox host *
Enter the GMI Cloud sandbox data-plane host, without the https:// scheme. Copy this from the sandbox_key/host value returned in the create or connect response, for example, iXXXXXXXX.sandbox.example.com.
Sandbox access token * Enter your GMI Cloud sandbox access token. For detailed information, see Configure API keys.
Additional reference
