Set up a connection to DeepInfra
DeepInfra is a cloud platform that provides low-cost, scalable API access to run and deploy popular open-source machine learning models for inference.
Setting Instructions
Name your connection *
API key *
Enter your DeepInfra API key. For detailed information on retrieving the API key, see Authentication.
Additional reference
