TypeSafe AI provides tools and infrastructure for building reactive, distributed applications using Scala, Akka, and the JVM.
| Setting | Instructions |
| Name your connection * |
API key * |
Enter your TypeSafe AI API key. You can retrieve the API key from TypeSafe AI Console. Multiple layers of protection, including AES-256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
