Deepgram is a voice AI platform that provides speech-to-text, text-to-speech, and voice agent APIs for real-time, accurate, and scalable enterprise voice solutions.
| Setting | Instructions |
| Name your connection * |
| API version | Select your Deepgram account API version. |
| Base URI * | Select your Deepgram base URI. For detailed information on selecting base URIs, see Global and Regional endpoints. |
| API key * |
Enter your Deepgram API key. For detailed information on retrieving the API key, see Creating API keys. Multiple layers of protection, including AES-256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Token auth universal connector documentation.
