Weights & Biases is an AI developer platform to build AI agents, applications, and models.
| Setting | Instructions |
| Name your connection * |
| API type * |
Choose your Weights & Biases API type:
| Serverless Interface API | |
| Token * |
Enter your Weights & Biases token. For detailed information on retrieving the token, see Serverless Inference API reference. Multiple layers of protection, including AES-256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
| Service API | |
| Base URI * |
Enter the base URI for your Weights & Biases instance:
| Project ID * | Enter your Weights & Biases project ID in the format <team_name>/<project_name>. For example, (acme-ml/support-agent). |
| Token * |
Enter your Weights & Biases token. For detailed information on retrieving the token, see Manage API keys. Multiple layers of protection, including AES-256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
