Set up a connection to FriendliAI
FriendliAI is an inference cloud for agents, built to run frontier open-weight models in production at scale.
The FriendliAI connector is in BETA and may be subject to changes.
Setting Instructions
Name your connection *
Personal API key *
Enter your FriendliAI personal API key. For detailed information on retrieving the personal API key, see Manage your FriendliAI API keys.
Multiple layers of protection, including AES-256 encryption, are in place to keep your personal API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Additional reference
