Set up a connection to GoodData.AI
GoodData.AI is a platform that runs analytics, AI, and agents on one governed data serving plane.
Setting Instructions
Name your connection *
Hostname * Enter the GoodData.AI organization hostname. For example, your-company-name.cloud.gooddata.com.
API token *
Enter your GoodData.AI API token. For detailed information on retrieving the API token, see Create an API access token.
Multiple layers of protection, including AES-256 encryption, are in place to keep your API token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Additional reference
