Set up a connection to Bytez
Bytez is a platform that provides access to open-source and closed-source AI models through one API key.
Setting Instructions
Name your connection *
API key *
Enter your Bytez API key. For detailed information on retrieving the API key, see Get started.
Multiple layers of protection, including AES-256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Provider API key
Enter the API key from the third-party provider whose closed-source model you want to use. This key is required only for closed-source models from Anthropic, Cohere, Google, Mistral, and OpenAI. For detailed information, see Get started.
Multiple layers of protection, including AES-256 encryption, are in place to keep your provider API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Additional reference
