Runway is an AI media platform that gives developers access to video, image, and audio models from Runway and other labs through one API.
| Setting | Instructions |
| Name your connection * |
| API key * |
Enter your Runway API key. For detailed information on retrieving the API key, see Create your account. Multiple layers of protection, including AES-256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
