Set up a connection to Sola
Sola (formerly Cardknox) is a payments company that provides payment processing for merchants and software platforms.
Setting Instructions
Name your connection *
API type *
Choose your Sola API type:
  • Transaction and reporting: Connect to process credit card, check (ACH), gift card, EBT, DAF, 3DS, and fraud verification transactions, and generate transaction, batch, gift, and reconciliation reports
  • Customer and recurring: Connect to manage customers, stored payment methods, recurring billing schedules, and one-time customer transactions
  • Account boarding: Connect to board Sola Go / GoPlus merchant accounts and submit supporting documents
Each API type shows a different set of settings.
Transaction and reporting API
Environment * Select your Sola gateway environment: x1, x2, or b1.
Gateway API version * Enter the Sola Transaction API version. For example, 5.0.0.
Software name * Enter the software name that sends requests to Sola.
Software version * Enter the software version that sends requests to Sola.
API key *
Enter your Sola API key. For detailed information on retrieving the API key, see Transaction API.
Multiple layers of protection, including AES-256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Customer and recurring API
Recurring API version * Select the Sola Customer and Recurring API version. For example, 2.1.
API key *
Enter your Sola API key. For detailed information on retrieving the API key, see Customer and Recurring API.
Account boarding API
API key *
Enter your Sola API key. The account associated with the API key must be authorized to board Sola Go accounts. For detailed information, see Account Boarding API.
Additional references
