Set up a connection to Telegram
Telegram is a cloud-based mobile and desktop messaging app with a focus on security and speed.
The Telegram connector is in BETA and may be subject to changes.
Setting Instructions
Name your connection *
API type *
Choose your Telegram API type:
  • Bot: Connect to send and receive messages, manage chats, and handle updates
  • Gateway: Connect to send verification codes to users who registered their phone number on Telegram
The Bot token setting appears only when you select Bot, and the Access token setting appears only when you select Gateway.
Bot token *
Enter your Telegram bot token. For detailed information on retrieving the bot token, see Obtain your bot token.
Multiple layers of protection, including AES-256 encryption, are in place to keep your bot token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Access token *
Enter your Telegram Gateway access token. For detailed information on retrieving the access token, see Authorization.
Multiple layers of protection, including AES-256 encryption, are in place to keep your access token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Additional references
