Supply Cloud is a network-powered B2B EDI platform by LBMX that connects suppliers and distributors through a secure, scalable one-to-many architecture.
The Supply Cloud connector is in BETA and may be subject to changes.
| Setting | Instructions |
| Name your connection * |
| API key * |
Enter your Supply Cloud API key. If you don't have an API key, contact your account admin or support@lbmx.com. The user who owns the API key must have access to all features of the EDI Documents API. Multiple layers of protection, including AES-256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
