A multi-instance base flow is the shared flow that every instance is generated from. You can build a new base flow in an integration, or convert a standard flow you've already built. This article covers both methods and how to convert a base flow back to a standard flow. After you create the base flow, you select its customizable properties and create instances.
Prerequisites:
- Your account uses one of the Professional and Enterprise editions.
- You have an integration to hold the flow. A base flow can't be a standalone flow.
- You must have Manage permissions on the integration to change a multi-instance flow or its instances.
Create a new base flow
Create a new base flow when you're starting from scratch.
- Go to Home
. Open the integration that will hold the flow.
- On the Flows tab, select Create > Multi-instance flow.
- Build the flow's exports, imports, and other steps the same way you build a standard flow. For details, see Create a flow.
The flow builder displays a Multi-instance label next to the flow name. To continue, select customizable properties and create your first instance, as described in Create and configure instances.
Convert a standard flow to a base flow
Convert a standard flow when you've already built and tested the flow you want to reuse.
Note: A multi-instance flow has no Run history tab, so the flow's earlier run history is hidden after you convert it. The run history isn't deleted. It's shown again if you convert the flow back to a standard flow.
- Go to Build
, and then select Flows.
- Open the flow you want to convert. The flow must belong to an integration.
- In the flow builder, select Actions
> Convert to multi-instance flow.
- In the Convert to a multi-instance flow? dialog, select Convert.
Convert a base flow back to a standard flow
You can convert a base flow back to a standard flow only when it has no instances.
- Delete every instance of the base flow. For steps, see Manage multi-instance flows and instances.
> Revert to standard flow.
- In the Revert to standard flow? dialog, select Revert.
