After you add a branching to a flow, you can rename it, change its branches, and delete branches or the whole branching. The Edit branching dialog has the same fields as Add branching. This article covers each task.
Prerequisites: Manage permission, Administrator role, or account owner — You must have the Manage permission on the integration, the Administrator role on the account, or own the account. For details, see Manage user roles & permissions to an account.
Edit a branching
- In Flow builder, select the branching router icon. The Edit branching dialog opens.
- To rename the branching, enter a new name in Branching name. When you save, you can see the new name by hovering over the router icon.
- Edit the branch names and descriptions if you haven't already. For steps, see Rename a branch and add a description.
- If needed, reorder, clone, or delete branches.
- To change a branch's conditions, see Configure branch conditions.
- Select Preview to check the results, and then select Save & close.
Branch actions
The Actions menu at the end of each branch header has four options: Clone branch, Add description, Clear all conditions, and Delete branch. The following sections use this menu.
Each branch has a default name, such as Branch X.0. Use names that describe the branch's condition or purpose.
- In the Edit branching dialog, select the branch name and enter a new name.
- Select the Actions
menu for the branch, and then select Add description.
- In the Add description pane, enter the description, and then select Save. Select Close to return to the dialog.
The new name appears in the dialog and in Flow builder.
Reorder branches
The number next to each branch is its branch index. The index starts at 0 and reflects the branch's order and priority. When you move or delete a branch, the indexes renumber automatically.
You can't reorder branches in a branching that uses All matching branches.
- Hover over the dots icon at the start of a branch until a hand symbol appears.
- Drag the branch to the new position.
Clone a branch
menu at the end of the branch header.
- Select Clone branch.
The copy has the same conditions as the original. Use it as is, or modify it.
Delete a branch
Deleting a branch also removes all steps in that branch, and any steps and branches that follow it. If the branch was merged with one other branch, the merge point is deleted as well. The branches after the deleted branch move up one index.
A branching must keep at least one branch. A branching with one branch looks like a linear flow but still shows the router icon.
- Select the branching router icon. The Edit branching dialog opens.
- Select Delete branch.
- In the Are you sure you want to delete this branch? dialog, read the message, and then select Delete. The message lists how many configured and unconfigured steps the deletion removes, along with the downstream branches.
Delete a branching
Before you delete a branching, check how it affects the steps that follow it. Create a snapshot first, as described in Work with revisions, especially for integrations in a production environment.
- Select Delete branching from the overflow menu
or next to Need to remove branching?
- In the Delete branching dialog, select the branch to keep. All other branches are deleted.
- Select Delete branching.
Reorder steps in your flow
You can drag a step to a different place in your flow. The mappings and filters that belong to the step move with it. After you reorder steps, check that each step's configuration is still correct.
