You may need to customize your Jira fields and create new webhooks based on your integration template requirements. This article covers creating custom fields and webhooks for Jira integration templates.
Create a custom field
- Sign in to your Atlassian account.
- Navigate to Jira Software → Projects.
- In the Settings menu, select Issues.
- In the Fields section, select Custom fields.
- On the upper, right-hand side of the screen, select Create custom field and review the Select a field type page.
- Choose a field type for the custom field and select Next.
- Review the Configure field page and provide the field Name.
- Select Create.
- Select the tabs on which this custom field is displayed and select Update.
Create a custom webhook
- In the Settings menu, select System.
- In the Advanced section, select WebHooks.
- Select Create a WebHook.
- Provide the WebHook Name, select the Status, and enter the URL. Select Create.
- Select the events that you want to be communicated through the webhook.
