Narvar is one of the top return management apps. It helps retailers inspire long-term customer loyalty at all steps of the post-purchase journey.
API type * |
Choose the API type, either Narvar or Narvar RMA depending on the Narvar API type you're connecting to. The settings then become specific to the selected API type. |
This video demonstrates creating a Narvar API type connection.
Username * |
Enter your Narvar account ID. |
Password * |
Enter your Narvar auth token. Multiple layers of protection, including AES 256 encryption, are in place to keep your authentication password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Sign in to your Narvar account.
Navigate to Admin > Company > API credentials .
Copy Account ID.
Copy Auth token.
Username * |
Enter your Narvar RMA username. |
Password * |
Enter your Narvar RMA password. Multiple layers of protection, including AES 256 encryption, are in place to keep your authentication password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
X-Narvar-Shop-Domain * |
Enter the unique portion of your Shopify store’s URL. For example, if your Shopify store URL is |
Sign in to your Shopify account.
Navigate to Apps > Narvar returns and exchange > Settings > Advanced > RMA post credentials.
Copy Username.
Copy Password.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Basic auth universal connector documentation
