Set up a connection to Etsy
Etsy is the global marketplace for unique and creative goods. It’s home to a universe of special, extraordinary items, from unique handcrafted pieces to vintage treasures.
This video demonstrates creating an Etsy connection.
Setting
Instructions
Name your connection *
OAuth 2.0 client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Etsy.
Fetch data {//theme.zdassets.com/theme_assets/1098969/5157503509223f89f9b3e7578d2ca78ce882fc18.svg}How to retrieve the client ID and client secret
To add an OAuth 2.0 client and configure your credentials, click the plus ( + ) button. Click the edit ( edit.svg ) button to modify a selected OAuth 2.0 client.
Fetch data {//theme.zdassets.com/theme_assets/1098969/5157503509223f89f9b3e7578d2ca78ce882fc18.svg}How to create OAuth 2.0 client in integrator.io
Scopes *
Scopes are OAuth 2.0 permissions that the LinkedIn Ads API defines to limit access to your account.
Fetch data {//theme.zdassets.com/theme_assets/1098969/5157503509223f89f9b3e7578d2ca78ce882fc18.svg}How to configure scopes
Client ID *
Enter your Etsy client ID.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see  OAuth 2.0 auth universal connector documentation.
How to retrieve the client ID (keystring) and client secret (shared secret)
  1. Sign in to your Etsy developer account.
  2. Navigate to Create a new app.
  3. Enter App overview > App details and click read terms and create app.
  4. Check Etsy API terms of use and click Create app.
  5. Navigate to Manage your apps > API key details.
  6. Copy Client ID (keystring).
  7. Copy Client secret (shared secret).
images
  1. Name (required): Enter the required iClient name.
  2. Client ID (required):  Enter client ID (retrieved from the above section).
  3. Client secret (required): Enter client secret (retrieved from the above section). Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s client secret safe. When editing the iClient at any point, you must enter the secret value again; it is stored only when the connection is saved and never displayed as text.
  4. Click Save.
  1. Click Scope.
    – or –
  3. Click Save.
images
Additional references
