Mapper 2.0: Destination field settings
This article describes the field mapping types and settings available in Mapper 2.0. Use it as a reference when configuring how source data is mapped to destination fields in an import.
To access these settings, click the Settings (settings_gear.svg​) button on any field row in Mapper 2.0.
Field mapping types – overview
Field mapping type: Select the type of mapping you want to apply to the destination record field. The field mapping types available change depending on the data type you select.
The following field mapping types are available for each data type. To view data type details, see Data type validation..
Destination data type Standard Hard-coded Handlebars expression Lookup (Dynamic) Lookup (Static)
string ✓ ✓ ✓ ✓ ✓
number ✓ ✓ ✓ ✓ ✓
Boolean ✓ ✓ ✓ ✓ ✓
[string] ✓ ✓ ✓
[number] ✓ ✓ ✓
[Boolean] ✓ ✓ ✓
object
  • Copy an object as-is from source data
  • Create object in mapping
✓ (copy as-is only)
[object]
  • Copy an object array as-is from source data
  • Create object array in mapping
✓ (extract only — child mappings use JSONPath)
Mapper 2.0 supports conversion to object or object arrays if that is required by your import/destination application.
Field mapping type settings
The following sections describe each mapping type.
Standard
Send the value of the source field as the value in the destination field. This is the default setting, indicating that data found in a specific field in the export should map to its corollary in the import application (1:1 direct mapping).
Action to take if source field has no value: Select an option based on the section below.
Add description: Enter an optional description of the settings configured.
Hard-coded
Set the source field to a defined value for the destination field. Use this setting if you prefer to have the same value written to this imported data field for every record, regardless of the exported value.
How would you like to hard-code the value?: Select one of the following options:
  • Use empty string as default value: Inserts empty string
  • Use null as default value: Inserts null value
  • Use custom default value: Inserts custom string value
Custom value: Enter the value to send to the destination field. This field only displays if you choose Use custom default value from How would you like to hard-code the value?.
Hard-coded values also support object and [object] (object array) destination fields, in addition to primitive types. To enable hard-coded values for objects, select Yes to Copy as-is from the destination mapping settings. Then, select hard-coded from the field mapping types and enter the static object or array-of-objects value directly in the destination field. For example, to hard-code an object:
{"status": "active", "region": "US"}
Or to hard-code an object array:
[{"id": 1, "label": "Primary"}, {"id": 2, "label": "Secondary"}]
 Mapper 2.0 validates the entered value and shows a preview so you can confirm the structure before saving. This applies across exports, lookups, and imports.
Keep the following behavior in mind when hard-coding object and object array destination fields:
  • An empty string resolves to an empty object {} for object fields, or an empty array [] for [object] fields. A null value is passed through as null for either type — it isn't converted to {} or [].
  • If a [object] destination field's hard-coded value is a single JSON object rather than an array (for example, {"id": 1, "label": "Primary"} instead of [{"id": 1, "label": "Primary"}]), Mapper 2.0 automatically wraps it into a one-element array.
  • Hard-coded can't be combined with another mapping approach on the same destination field. For object fields, this means hard-coded and copy-as-is (or Create object in mapping) can't both be set. For [object] fields, you can't combine hard-coded with Create object array in mapping. Attempting to save a field with both configured is rejected.
Object and object array destination fields support three mapping approaches: copying the value as-is from source data (or building it field-by-field with Create object/object array in mapping), a handlebars expression for computed values, and hard-coded for static values that don't vary between records. Choose hard-coded when the destination value is fixed regardless of the source record.
Lookup
You can choose any one of the following lookup types:
Static: Define a static value-to-value mapping
Dynamic: Use the results of a dynamic search to populate the destination field value.
Lookup cache: Use a lookup cache value field for mapping to the destination field
Lookup (Dynamic)
Use a dynamic lookup when your integration needs to retrieve additional data from a secondary source to match records between your source and destination applications.
Relative URI: Enter the relative URI that will be appended to the address displayed below the field. Using the above example, if you enter /customers/search?email={{export.email}}, the call to retrieve data for your lookup will be sent to https://us15.api.mailchimp.com/customers/search?email={{export.email}}. The handlebars expression {{export.email}} would be replaced with the email address stored in the source data email field for each call. Select the AFE (pencil_handlebars.svg) icon to create a handlebars expression to dynamically populate the relative URI.
HTTP method: Select GET or POST. Consult the lookup destination app developer documentation for which method to choose.
Resource identifier path: Enter the JSON path where the dynamic lookup will locate the lookup data in the request response. For example, if you enter searchResults[0].name, the dynamic lookup might return:
  "count": 1,
  "searchResults": [
      "name": "Mary"
      "id": 1234
      "email": "mary@email.com"
In this example, the value mary@email.com in the field email for a record in the source application's data matched a record in the lookup destination application's data based on that email address. The positive result instructs integrator.io to locate the name field in the response and write the value Mary to the field name in the destination application's record.
If a unique match is not found when performing a dynamic lookup search, by default integrator.io marks the record as failed and does not transfer data for that record. You can alter that behavior by selecting an option from the If lookup fails drop-down list.
Lookup name: Give the lookup a unique name so that it can be easily identified for use in other flows. You can select any dynamic lookups used in other flows to this destination app.
If lookup fails: If no match returns from the lookup search, the record fails by default. integrator.io then marks the record as failed and does not transfer any data for that record. You can select one of the following alternatives if needed:
  • Do nothing: The field name and value is skipped.
  • Fail record (default): integrator.io marks the record as failed and does not transfer any data for that record.
  • Use empty string as default value: Inserts empty string.
  • Use null as default value: Inserts null value.
  • Use custom default value: Inserts any string value you enter in the field provided.
Lookup (Static)
If you already know how a specific field value from the source application data should be replaced before being sent to the destination application, then you can use a static lookup to define how each value should be replaced.
Click Add mapping and enter the source and destination field values. For each Source field value, define the corresponding replacement Destination field value that will be sent to the destination application.
Destination field value: Enter the value as it would be replaced when sent to the destination application.
Source field value: Enter the corresponding value that this field uses in the source application data.
For example, if the source data has a field named state that should be mapped to a corresponding field named Region on the destination application's import record, but the naming conventions are not the same because the destination data references states with the two-letter convention (AL, AK, AZ) and the corresponding export value for each state uses the full name of the state (Alabama, Alaska, Arizona), you could add all 50 states as Destination field values using the two-letter convention, and Source field values as corresponding full state names. This ensures that each full state name in the source data would be replaced by the two-letter state name during import.
An additional empty line is added to the list with each new value you add, and you can click the Delete (trash.svg) button on the right to delete any line.
Lookup name: Give the lookup a unique name so that it can be easily identified for use in other flows. You can also select any static lookups used in other flows.
Lookup cache
In some scenarios, you might find it useful to store data in a lookup cache in the Celigo platform (integrator.io) for a quick lookup. You can select the lookup cache or create a new lookup cache, and then select the lookup cache value field.
Lookup cache name: Select the lookup cache from the list.
Lookup cache value field: Select the path to the lookup cache value for mapping to the destination field. This value will be retrieved when the source field and the lookup cache key match.
If lookup fails: If no match returns from the lookup search, the record fails by default. integrator.io marks the record as failed and does not transfer any data for that record. You can select one of the following alternative options if needed:
  • Use custom default value: Inserts custom string value.
Source data type: If you have already selected a Source field from your source data, the data type is automatically set. If you added a new source field that is not in your currently loaded source data, use the drop-down list to set its data type
Build a handlebars expression for the value in the source field to send to the destination field. Handlebars expressions are supported for string, number, Boolean, [string], [number], [Boolean], object, and [object] destination field types.
  • For object fields, handlebars is supported in copy-as-is mode only.
  • For [object] fields, handlebars applies at the helper extract level only — child field mappings within the array continue to use JSONPath.
  • For [string], [number], and [Boolean] fields, handlebars-returned arrays are used directly and are not comma-split, unlike plain-text values.
Handlebars expression: Enter a simple handlebars expression in the field, or select the AFE (pencil_handlebars.svg) icon to open the Handlebars advanced field editor (AFE).
Action to take if handlebars expression returns an empty value: Select what integrator.io should do when the handlebars expression returns an empty value:
  • Do nothing (default): The field name and value is skipped.
Source data types
For all the supported data types and related details, see Data type validation.
Action to take if source record field has no value
Data type Action to take if source record field has no value Mapper 1.0 Mapper 2.0
string Use empty string as default value Inserts empty string
Use null as default value Inserts null value
Use custom default value Inserts custom string value
Do nothing (default) Removes field name and value
Cause record to fail N/A Causes the record to fail
number Use empty string as default value Inserts 0
Use null as default value Inserts 0 Inserts null value
Use custom default value Inserts custom number value
Do nothing (default) Inserts 0 Removes field name and value
Boolean Use empty string as default value Inserts false N/A
Use null as default value Inserts false
Use custom default value Inserts false Selects true or false
Do nothing (default) Inserts false Removes field name and value
object Use null as default value N/A Inserts null value without object formatting
Do nothing (default) N/A Removes field name and value
[string] Use empty string as default value Inserts empty array
Use null as default value Inserts empty array Inserts null value without array formatting
Use custom default value Inserts empty array Inserts custom values as array ["a", "b", "c", "d"]
Do nothing (default) Inserts empty array Removes field name and value
[number] Use empty string as default value Inserts empty array
Use custom default value Inserts empty array Inserts custom number values as an array [1, 2, 3, 4]
[Boolean] Use empty string as default value N/A Inserts empty array
Use custom default value N/A Inserts custom values as an array [true, false, false]
Use null as default value N/A Inserts null value without array formatting
[object] Use null as default value N/A Inserts null value without object formatting
Advanced (available only for HTTP composite methods)
Advanced options only apply to HTTP imports that use composite methods. Only perform mapping when:
  • Creating a record: Choose this option if the mappings you create will apply only to new records you create in the destination application.
  • Updating a record: Choose this option if the mappings you create will apply only to existing records in the destination application.
