What’s enhanced
Set page size for transactions
The Set page size for transactions setting has been added to the Stripe payout to NetSuite payout custom record flow allowing you to set the page size for transactions. Enter the number of transactions to be displayed per page in the Set page size for transactions setting. A single record will be created in NetSuite for the given number of transactions on the current page. The maximum number of transactions that can be processed in a single page is 2000. If you do not enter any value in this setting, the default page size will be set to 2000.
For more information, see Reconcile your Stripe payouts.
