Rate this feature
Included in the Jan. 2023 release Box is a cloud content management and file sharing service. The Box platform enables easy team collaboration.
Box documentation: API guide, Authentication
Important: You can't import a file to Box with this connector if a file with the same name already exists in the destination Box directory.
A. Set up a Box connection
Start establishing a connection to Box in either of the following ways:
In the resulting Application list, click Box.
B. Configure your client ID and secret
At this point, you’re presented with the required settings for Box authentication.
Redirect URL (required/uneditable): Use this URL when configuring your Box app. Use the following steps to add the redirect URL to your Box app.
- Sign in to Box.
- Navigate to the Developer console.
- Click the app you created.
- Click the Configuration tab.
- In the OAuth 2.0 Redirect URI section, click Add a URI.
- Paste the Redirect URL from integrator.io.
- Click Save changes in the upper right corner of the page.
iClient (required): Select the iClient pair that stores the client ID and client secret provided to you by Box. To add an iClient and configure your credentials, click the plus (+) button. Click the edit () button to modify a selected iClient. Be sure to give the iClient a recognizable name for use in any other connections. Use the following steps to find your client ID and client secret.
- Sign in to Box.
- Copy your client ID and client secret from the OAuth 2.0 Credentials section.
- Paste these values in their respective iClient fields in integrator.io.
Configure scopes (required): Set the required Box scopes for your connection.
C. Edit advanced Box settings
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the Box connection.
D. Save and authorize
Once you have configured the Box connection, you have a few options for continuing:
When you select Test connection, the connection is verified before continuing and the status is displayed in the Connection pane.
2 comments
Unfortunately this does not work, neither do the instructions provide the correct steps and/or information on how to get this setup.
UPDATE: Was able to get to work, please note the following:
-Create an App in Box, select User Authentication (OAuth 2.0) as the type of Custom App. This allows you to enter the redirect URI.
-Make sure to Enable through your Admin Console in Box (Admin -> Apps-> Custom Apps Manager : Enable the app you created)
-In Box, if you give the app full permissions in Configuration->Application Scopes, you cannot use Celigos "sign_requests.readwrite" option (this might be for something yet I have not dug into). Remove that, then authenticate in Celigo and it works
-In Box, the "Make API calls using as-user headers" checked or unchecked under Advanced Features did not affect connection to Celigo
-The "root" folder in Box for Directory Path in Celigos Box Setup is "All Files" (for me at least), to which you can then expand to your other folder (example : All Files/Test Files)
Thanks, NicholasKeicher, for the update and for sharing your trial-and-error with other customers. We'll work on improving the Box configuration portion of this article, as well as adding export and import examples as time permits.
