Dropbox is a cloud content management and file sharing service. The Dropbox platform enables easy team collaboration.
Dropbox documentation: API guide, Authentication
- You can't import a file to Dropbox with this connector if a file with the same name already exists in the destination Dropbox directory.
- When exporting data with the Dropbox connector, you must provide a valid Relative URI. If you run a flow for an export that does not have a valid
relativeURI(via a backend API call) or the Relative URI only has a forwardslash (/) entered as a value for the export, the flow will fail.
A. Set up a Dropbox connection
Start establishing a connection to Dropbox in either of the following ways:
In the resulting Application list, click Dropbox.
B. Configure your client id and secret
At this point, you’re presented with the required settings for Dropbox authentication.
Redirect URL (required/uneditable): Use this URL when configuring your Dropbox app. Use the following steps to add the redirect URL to your Dropbox app:
- Sign in to Dropbox.
- Navigate to the App console.
- Open the Dropbox app you're connecting.
- In the OAuth 2 section of the Settings tab, enter the redirect URL copied from integrator.io.
- Click Add.
iClient (required): Select the iClient pair that stores the client ID and client secret provided to you by Dropbox. To add an iClient and configure your credentials, click the plus (+) button. Click the edit () button to modify a selected iClient. Be sure to give the iClient a recognizable name for use in any other connections. Use the following steps to find the client ID and client secret for your Dropbox app.
- Open the Dropbox app you're connecting to integrator.io.
- Use the App key value displayed on the Settings tab as your client ID.
- Click Show to display the App secret value to use as your client secret.
Configure scopes (required): Set the required Dropbox scopes for your connection.
C. Edit advanced Dropbox settings
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the Dropbox connection.
D. Save and authorize
Once you have configured the Dropbox connection, you have a few options for continuing:
When you select Test connection, the connection is verified before continuing and the status is displayed in the Connection pane.
