Use Handlebars in static lookups
integrator.io supports Handlebars in static lookups. If you're familiar with Handlebars, you can enter expressions directly in the Export Field on the mapping screen. You can also use the following steps.
  1. On the mapping screen, click the Settings button for the field where you want to use Handlebars for static mapping. This example applies Handlebars to the Name field.
  2. Select Multi-Field.
  3. From the Function drop-down list, select the function you want to use, for example JOIN.
    Note: You can also select fields, such as First Name and Last Name, from the Field drop-down list, then modify the Handlebars expression as needed.
  4. Click Save.
  5. Click the Settings button for the same field again.
  6. Click Static-Lookup, then enter the values for the Export Field and Import Field.
  7. Click Save.
