Using hmacOptions
When using the hmac handlebars helper to generate an authentication header or URI parameter, the Celigo platform provides and populates a set of hmacOptions fields you can use to create the signature. hmacOptions is a JSON object that contains fields that are commonly used to create authentication signatures (such as the request body and the URI). The following table lists all available fields:
For demonstration purposes, the examples provided use the following full URL:
https://www.celigo-test.com/this/is/a/test?username=Integrator&domain=IO
Field name Description
hmacOptions.headers Path to parameters sent in the request header.
hmacOptions.body The HTTP request body, in string format.
hmacOptions.bodyParametersMap Path to parameters sent in request body.
hmacOptions.orderedBodyParametersString Reorders request body fields alphabetically (excluding sign), stringifies the field values, removes special characters, and concatenates them into a single string for HMAC signing.
hmacOptions.method The HTTP request method (verb). For example, PUT, POST, GET, etc.
hmacOptions.http.encrypted The contents of the http.encrypted field from your HTTP connection. If you store the key in your HTTP connection as hmacKey, it is available for use as hmacOptions.http.encrypted.hmacKey.
hmacOptions.baseURI
The base URI used in the request. In this example, the value is:
www.celigo-test.com
hmacOptions.relativeURI
The relative URI used in the request. In this example, the value is:
/this/is/a/test
hmacOptions.orderedQueryParams
Reorders the query parameters in alphabetical order (except for 'sign' and 'access_token'. ('sign' and 'access_token' won't be present in this hmacOption field')
Caution
Celigo does not check for typos or validate query parameters when using this option.
hmacOptions.urlParameters*
The URL parameters used in the request. In this example, the value is:
hmacOptions.urlParametersMap Path to parameters sent in request URL.
hmacOptions.URI*
The full URI used in the request. In this example, the value is:
* Not available with authentication URL parameters.
Examples using hmacOptions with the hmac helper
To create an HMAC-SHA256 digest from the full URI in base64 format:
{{{hmac "sha256" hmacOptions.http.encrypted.hmacKey "base64" hmacOptions.URI}}}
To create an HMAC-SHA256 digest from the request body in hexadecimal format:
{{{hmac "sha256" hmacOptions.http.encrypted.hmacKey "hex" hmacOptions.body}}}
Example using hmacOptions.urlParametersMap.timestamp to create a signature included in the API request
Alibaba requires the following public parameters and service parameters:
Base URL: http://gw.api.taobao.com/router/rest
Public parameters:
method = "aliexpress.solution.order.fulfill"
app_key = "12345678"
session = "test"
timestamp = "2016-01-01 12:00:00"
format = "json"
v = "2.0"
sign_method = "md5"
Service parameters:
service_name = "SPAIN_LOCAL_CORREOS"
out_ref = "1000006270175804"
send_type = "all"
logisitics_no = "ES2019COM0000123456"
The handlebars template to build the request is as follows:
  http://gw.api.taobao.com/router/rest?method=aliexpress.solution.order.fulfill&app_key=12345678&session=test&timestamp={{dateFormat
  "MM-DD-YYYY hh:mm:ss" timestamp}}&format=json&v=2.0&sign_method=md5&logistics_no=ES2019COM0000123456&out_ref=1000006270175804&send_type=all&service_name=SPAIN_LOCAL_CORREOS&sign={{{hmac
  'md5' 'connection.http.encrypted.secret_key' 'hex' (join '' app_key' '12345678'
  'format' 'json' 'logisitics_no' 'ES2019COM0000123456' 'method' 'aliexpress.solution.order.fulfill'
  'out_ref' '1000006270175804' 'send_type' 'all' 'service_name' 'SPAIN_LOCAL_CORREOS'
  'session' 'test' 'sign_method' 'md5' 'timestamp' hmacOptions.urlParametersMap.timestamp
  'v' '2.0')}}}
The above handlebars template generates the following request which includes the required signature:
  http://gw.api.taobao.com/router/rest?method=aliexpress.solution.order.fulfill&app_key=12345678&session=test&timestamp=09-28-2023%2004%3A48%3A24&format=json&v=2.0&sign_method=md5&logistics_no=ES2019COM0000123456&out_ref=1000006270175804&send_type=all&service_name=SPAIN_LOCAL_CORREOS&sign=a70e11b72e9c728d2fc560993410dfe2
