Overview
The order/customer data flow automatically pushes orders and associated customer information from Amazon to NetSuite periodically. integration app enables you to set up the frequency of the data flow. The Amazon - NetSuite integration app supports both MFN and FBA orders.
Definition: For AFN (Amazon Fulfilled Network), also called FBA (Fulfilled by Amazon) orders, sellers are expected to ship the inventory to Amazon Warehouses and Amazon is responsible for the fulfillment, returns, and refunds for the orders.
The following order/customer data flows are provided:
Order (FBA)
Amazon (FBA) Order to NetSuite Order Add
Amazon (FBA) Order to NetSuite Order Add (on-demand sync)
Amazon (FBA) Customer to NetSuite Customer Add
Importing your first FBA order into NetSuite
Prerequisites
Ensure you have an SKU in Amazon that also exists in NetSuite with the same SKU name/number. If you don't already have one, use the steps as follows:
In your Amazon seller central account, Go to the Inventorytab > Add product and create a new product.
For more information on how to create an item on Amazon, click here.
In NetSuite, Go to Lists > Accounting > Items > New > Inventory Item and create an item record for the same item.
From your buyer account, create a test sales order for the same product and enter the necessary order details. Once the order is placed, make a note of the order id. Alternatively, you can skip step 1 and 2 and use an existing order which has not been imported in NetSuite. When using existing order, please ensure that the item for which the existing order was placed exists both in NetSuite and Amazon.
In the Amazon (FBA) order to NetSuite order Add flow mappings, in the Amazon (FBA) Order Import Adaptor, ensure to select eTail Channel (Name) in the Import field NetSuite, instead of eTail Channel (InternalId). This ensures that the order lookup is successful when you run the flow.
In NetSuite, ensure that the Celigo Amazon IO Account page has the correct integration store ID populated in the Account ID field. Do not enter the account ID manually. This ensures that the order lookup is successful when you run the flow.
For more information on placing an order for an item, see Getting started.
Go to Settings > Order section > Order tab, and perform the following steps:
Click the Shipping tab and click Map Ship Methods.
Select a value in the Default Lookup Value field.
Click Save.
Click the Off /On switch to enable the Amazon Order (FBA) to NetSuite Order Add flow.
Now, you are ready to import your first order!
Import your first FBA order
In the Order section, under Settings click the Order tab.
Enter the Amazon Order Id (noted in Step 2 of the prerequisites) in the Amazon Order Id(s) text box.
Click Save. This action triggers the flow to pull the specified order details from Amazon and push it into NetSuite.
To monitor the success or failure of this action, click on the Dashboard tab. On this page, you should see a new job in a few seconds that changes its status from Queued -> In Progress -> Completed.
If the job status shows "Completed" with a success count as 1, this indicates that the order has been successfully added into NetSuite and you can directly go to Step #5.
If the job status shows "Errored" with an error count as 1, this indicates the order import has failed. In this case, use the following steps to resolve the error:
Click on the View button next to the error count on the same job to know why the order import failed.
Fix the error and retry the same job using the Retry button.
Note : As NetSuite does not report all errors with an order at once, you may need to fix errors one by one as they appear till the order is successfully added into NetSuite.
Navigate to your NetSuite account and put the same "Amazon Order Id" in the global search box to find the order record created in NetSuite for the corresponding order in Amazon.
Understanding the Settings
The integration app includes a lot of powerful settings that empower you to fine-tune the out of the box integration app per your business needs. To understand each of the available settings in detail, see Order Settings.
Customer Data Flow
The customer data flow is a real-time data flow and is automatically triggered every time the order data flow runs. The flow imports customer information from Amazon to NetSuite every 15 mins. The flow currently supports customer creation and not customer updates (when any update is made to the customer in Amazon, the same details must be updated in NetSuite manually). The customer information includes basic details such as the shipping address. The flow also provides pre-built functionality that prevents duplicate customers from getting created in NetSuite.
Order Data flow
The Order import flow imports new sales orders from Amazon into NetSuite along with associated customer information for each order. This is a batch data flow (you must trigger the flow manually). The Amazon Order Import flow can be made to run from every 15 mins to once per week. Some features of the order data flow include:
Order (FBA) flow
Imports FBA orders from Amazon as sales orders in NetSuite every 15 mins.
Imports new FBA orders that are in “shipped” state and saves them in NetSuite as either Sales Orders or Invoices or Cash Sales.
Provides optional feature to import Amazon orders into NetSuite by providing Amazon a list of Amazon FBA order IDs (comma-separated, maximum of 50 order IDs at a time).
Provides optional settings to configure the order date filters and associated duration in days for importing Amazon orders within the specified time range into NetSuite.
Pre-built functionality to prevent duplicate orders.
Variances in taxes/shipping costs/order totals between NetSuite and Amazon are reported on the sales order.
Ship Methods
Ship methods must be configured separately in both systems by clients. The integration app allows unlimited ship method mappings.
Taxes
Tax codes must be configured separately in both NetSuite & Amazon by clients. In order for tax totals to match between systems, the tax tables/rules must be identical in both systems. Note: GST (Goods and Service Tax) is not supported
Item Types
The integration app only requires the SKUs to match on Amazon Item & NetSuite item regardless of the item type in either system.
Supports Simple, Matrix, Kits item types.
Note: NetSuite Assembly items that are not pre-built and NetSuite items configured as ‘Item Group’ type items are not supported at this time.
Customer Import
Amazon also sends customer details with Order data. The integration app can check to see if a customer record already exists in your NetSuite system with the same Amazon anonymized email address as the one provided by Seller Central in the order feed. If so, it attaches that customer to the sales order. If a matching customer is not found, a new customer record is created in NetSuite.
Merchant SKU
When adding line items to the NetSuite sales order, the Merchant SKU field mapping that you have specified is used to look up the equivalent item in NetSuite, given that each Amazon Merchant SKU is provided for each item on the Amazon order. By default, we use the Item Name/Number field in NetSuite, but this mapping may be configured to look in any other text field that you prefer in NetSuite, including a custom field you may have created.
Important! If the field used to map to the Amazon Merchant SKU is empty for a given item or does not contain an exact case-sensitive match to the SKU provided in the Order Feed, the integration app will have no way to identify which item should be used on the Sales Order and will fail to import the order. An error message will be generated, and an email alert will be sent to notify your team.
Variance
After the customer data is processed, the integration app adds the new sales order to NetSuite. Once the order is successfully created, the financial totals calculated by NetSuite are compared to those calculated by Seller Central. The following data is compared and checked for a variance:
Grand Total
Tax Total
Shipping Tax Total
Shipping Total
If a variance is found for any one of these totals, the sales order in NetSuite is updated with those amounts on the Amazon tab of the Sales Order in the fields shown below.
Shipping DiscountIn case there is a shipping discount on the Amazon Order, the net shipping cost on the NetSuite order is imported as Shipping Cost - Shipping Discount.
Duplicate Customer Check
The integration app uses the Amazon Buyer Id of the customer to verify existing customer records in NetSuite. If a match is found the matching customer record is linked to the order, else a new customer record is created and linked to the order.
Duplicate Order Check
The integration app creates custom fields in NetSuite labeled “eTail Order Id”, “eTail Merchant Order Id” and “eTail Channel”. The Amazon “orderId” field is mapped to the “eTail Order ID” and “eTail Merchant Order Id” fields in NetSuite. In addition, the integration app will generate a special ExternalID for the order that indicates it was imported by the integration app. While importing a new sales order, the integration app first checks whether there is an existing sales order in NetSuite with the same ExternalID as the mapped sales order. If the search finds a match, the new order is considered a duplicate and not imported.
Order Total Variance Handling
It is possible that the order total might not match between the two systems if information such as tax rates do not match. The integration app calculates the variance related to the order total. After each order is imported into NetSuite, the integration app immediately compares the calculated totals with what was sent from Amazon. These fields include Tax Total, Ship Total, and Order Total. If there is a difference between the values calculated by NetSuite and the values sent from Amazon, the difference is stored in one of the variance custom fields on the sales order. You may report on these fields in NetSuite on a periodic basis and adjust your G/L with a journal entry if variance values exist.
When an order is created in Amazon, the integration app pushes the order information from Amazon into NetSuite automatically. You can also manually trigger the data flow. Customer data associated with the order is also automatically moved into NetSuite.
Set up and save the flow settings
Run the data flow
View status of flow in the dashboard
Validate whether the record has moved from Amazon to NetSuite or vice versa
When an order is created in Amazon, the integration app pushes the order information from Amazon into NetSuite automatically. You can also manually trigger the data flow using the Amazon (FBA) order to NetSuite order Add (on-demand sync) flow. Customer data associated with the order is also automatically moved into NetSuite.
Go to Settings > Orders (FBA) > Orders.
Enter the Amazon order IDs that needs to be synced in the Amazon order ID(s) setting. You can enter up to 50 order IDs separated by a comma.
Update the other settings as needed. To understand each of the available settings in detail, see Order Settings.
Click Save. The flow will run automatically and the orders will be synced with NetSuite.
Sync buyer VAT registration details
The Amazon (FBA) Customer to NetSuite Customer Add and Amazon (FBA) Order to NetSuite Order Add flows sync buyer VAT registration details from the following Amazon fields to NetSuite:
taxRegistrationId
taxRegistrationAuthority
taxRegistrationType
To sync data related to the above fields, configure the below mappings in the Amazon (FBA) Customer to NetSuite Customer Add and Amazon (FBA) Order to NetSuite Order Add flows:
Source record field (Amazon Seller Central) |
Destination record field (NetSuite) |
TaxRegistrationDetails[0].member[*].taxRegistrationId |
<Map to any existing or custom field in NetSuite> |
TaxRegistrationDetails[0].member[*].taxRegistrationAuthority.country |
TaxRegistrationDetails[0].member[*].taxRegistrationType |
Note: You can use an existing field or create a custom field in NetSuite to sync the buyer VAT registration details. If you are using a custom field in NetSuite, ensure that it is a Free Form Text field.
Remote fulfillment between accounts
Remote fulfillment between accounts in the same marketplace
If the order quantity is not available in one location, it is automatically fulfilled with the quantity available from another location, using the North American Remote Fulfillment (NARF) program in the North America region (United States, Canada, and Mexico) or European Fulfillment Network (EFN) program in the European region. This scenario leads to errors and orders might not be synced appropriately.
To ensure orders are synced, modify the inventory location to the account that fulfilled the order in the Select inventory location present in NetSuite setting under Settings > Order (FBA) > General section and run the Amazon (FBA) Order to NetSuite Order Add flow or the Amazon (FBA) order to NetSuite order Add (on-demand sync) flow again with the updated location to sync the orders.
Limitation: The integration app supports remote fulfillment for an order fulfilled via a single account where the entire order quantity is available.
Remote fulfillment between accounts in different marketplaces
If the remote fulfillment happens between two accounts in different marketplaces, create an account in the destination marketplace to link the account from the source marketplace.
Example: If an order for 10 shoes is placed from an account in the Canada marketplace that was out of stock, the entire order can be fulfilled by an account in the United States marketplace that has the quantity available.
To sync the order details when remote fulfillment happens between two accounts in different marketplaces:
Create an account that represents the account in the United States marketplace that fulfilled the order in the destination marketplace (Canada).
Update the inventory location to the new store in the Select inventory location present in NetSuite setting under Settings > Order (FBA) > General.
Run the Amazon (FBA) Order to NetSuite Order Add flow or the Amazon (FBA) order to NetSuite order Add (on-demand sync) flow with the updated location to sync the order with NetSuite.
Troubleshooting
How do I resolve the "Failed to add Amazon Order" error?
Answer: When syncing Amazon orders to NetSuite if you are getting the "Failed to add Amazon Order", there is a possibility that you are using the ASIN field as a lookup in the "Amazon(FBA) Order to NetSuite Order Add" flow.
To resolve this error,
Go to Flows > Order (FBA).
Click the Edit Mappings icon of the "Amazon(FBA) Order to NetSuite Order Add" flow.
On the Edit mapping window, click Amazon (FBA) Order Import Adaptor.
In the Mappings screen, search for "OrderItem[*].SellerSKU", and replace it with "OrderItem[*].ASIN".
Click the Gear icon of the same field. The Settings window appears.
In the Settings window, from the drop-down list box, select Amazon Product ASIN and in the corresponding text area enter "{{#if OrderItem.*.ASIN}}{{{OrderItem.*.ASIN}}}{{else}}{{{OrderItem.0.ASIN}}}{{/if}}".
Click Save .
This should resolve your error and the orders should start syncing.
