Flow builder provides a visual model of how data is processed.
Developer tools – Go beyond point-and-click with the help of handlebars, JavaScript, and stacks.
Orchestration – Control when and how flows are executed.
Data loader imports data files into NetSuite, Salesforce, or hundreds of other popular applications.
Integration apps (managed components with periodic updates) and integration templates contain the flows you need to get started syncing data between systems.
Integration lifecycle management creates revisions to build, test, and deploy integrations iteratively. You can review differences, merge, pull, and revert changes, and take snapshots.
Error-handling tools include notifications, dashboards, and the ability to retry data as sent or modified and in bulk operations.
Auto-resolve errors – ML/AI that categorizes errors and automatically retries intermittent and rate-limit errors.
Flow packaging helps to clone a flow, distribute integrations as templates, package flows, and download to another account
Make your integrations more portable by referencing resources with aliases.
Test in a sandbox environment before deploying into production.
API management helps to build custom My APIs endpoints and connect to the integrator.io API.
Prebuilt and universal connectors provide access to popular endpoints. Celigo offers hundreds of prebuilt application connectors.
If the application you want to connect is not listed, select a universal connector such as HTTP, FTP, and AS2.
If universal connectors do not fit your requirement, you can create a Wrapper.
Custom settings support adding your own settings (form fields) and configuration options to an integration’s user interface.
