The Celigo platform automates and simplifies complex integrations providing several significant benefits.
Infinite scalability to connect any application with no limits on integrations or data volume:
Reliable performance with over 99.995% uptime
No practical limitations on the number of concurrent integrations running or data volume
Reuse integration assets – rapidly develop new integrations
Application agnostic – change apps as your business matures; your integrations are portable
AI/machine learning to manage and assist in integrations
Managed updates of connectors, new features, and updates to prebuilt solutions
Automatic updates of platform versions
Empowers developers and enables business teams with self-service while ensuring best practices and compliance:
Prebuilt solutions with embedded business logic automate business processes up to 100% using built-in best practices
Approachable user experience so that business users feel confident creating and managing automations to fit their changing business processes
Purpose-built, easily accessible developer interface provides robust capabilities for technical users to build complex integrations
Role-based access controls to ensure only authorized team members can build or update integrations
Enterprise-grade data security including SSO and MFA
Compliance with global data privacy laws
Faster time to value, reduced burden on IT resources, and a pricing model designed to encourage increased usage:
Business teams can create and modify their own integrations to meet the requirements of changing processes without development resources
Developers can rapidly create and modify complex integrations, increasing efficiency by 50% or more
Move management and maintenance of business process automations to less technical resources, reducing costs while increasing agility
Centralized, AI-enhanced error handling reduces the time and resources needed for error management
Tiered pricing model based on the number of endpoint applications and flows with no limit on the number of instances, users, or consumption
You can have unlimited user accounts. There's no additional charge per user.
Celigo software-as-a-service offers flexible API connections for every integration scenario:
Connect to cloud applications – Connect to hundreds of applications out of the box or use a universal connector to meet your business needs
Connect to on-premise apps – Easily integrate with an app running behind a network firewall, whether on-premise or in the cloud, with a Celigo agent
Access cloud databases – Advanced support for integrating with SaaS databases and data warehouses, using your existing database or replication tools
Access on-premise databases – Connect to a local or network database with the agent software
Use integrator.io API – Access or run your integrations’ resources from an HTTP request
